I have an asus RT-AC3200 router that I want to flash with the tomato firmware to enable more features. I have to pick the right one of course so that I don't ruin the router. But, it is kinda of confusing when you go to shibby's website. The main download page tells you that you need K26ARM7 for this router:
http://tomato.groov.pl/?page_id=164
However, when you open the link, you see multiple folders for this firmware each with several files to download. I can see a 132 folder and a 136 folder...etc. Now, which one should I download??? Some firmware files names have AIO in them which I suspects means ALL in ONE ? And some others have VPN !!
http://tomato.groov.pl/download/K26ARM7/136-MultiWAN/
Anyways, I actually downloaded this one : tomato-RT-AC3200-ARM--132-AIO-64K.zip from the 132 folder because I saw it done in another website and entered the router page and tried flashing it with it. The process finished successfully, however when I rebooted the router I was never able to connect to it. I was afraid I ruined it, but luckily I was able to restore it back to the original firmware using asus rescue mode. It worked after that.
Now, I want to try it again. WHICH firmware should I choose? Did I pick a wrong one? Should I use a special way to do the upgrade other than just browsing for the firmware file in the router setup page and hit upload? Maybe all firmware files in there work but some come with more features? Anything else to pay attention to when doing this little risky upgrade?
Many thanks...
Many thanks...
