Tomato Firmware Question!
ratchet27
12
Just successfully installed Tomato. I've enabled a password but can't find a means to change the username from "root". Is this possible? Thank You!
Rafael
868
I am not 100% sure, but I think it is NOT possible.
You can creat users, but you will not be able to give administrators power to the user.
So it will be useless once you will not be able to change settings.
