I'm using a Buffalo router with tomato firmware. I want to transfer large files to my dad in another town. I've got FileZilla Server running on my machine (WinXP), and he has FileZilla Client running on his (Vista) computer.
Everything works just dandy, except that transfers won't complete. They get disconnected. A 700 MB file, say, will only get to about 100-150 MB before disconnecting.
I've been advised to set up my router not to drop idle connections. So, under the "advanced" section of the tomato firmware administration page, I find the following under "TCP timeout":
None
Established
SYN Sent
SYN Received
FIN Wait
Time Wait
Close
Close Wait
Last ACK
Listen
All the values are expressed in seconds. I was advised in a FileZilla forum to try changing the "Established" value, which is currently 14400. But that's 4 hours, and I know transfers are getting disconnected sooner than that. Also, none of these values will let me change them to "0" (which I would take to mean no timeout at all).
And I've completely disabled my firewall, BTW, so I know that's not the prob.
Can anyone advise me if there are settings in either FileZilla Server or in tomato firmware that I should look at?
Also, could the problem be on the other end? In other words, could Vista be breaking the connection? If that's even a possibility, I feel like just giving up now
. My dad and I had a terrible time getting VNC to work on Vista (in fact, we never did). He's not very computer-literate, and ... well, you know what it's like trying to talk somebody through something on the phone, especially when you can't see their screen.
Also, is there a better way to transfer large files? Seems like years ago I used to use instant messanger software to do that (as a 'for instance').
thx,
-abs
None
Established
SYN Sent
SYN Received
FIN Wait
Time Wait
Close
Close Wait
Last ACK
Listen
thx,
-abs
