D
Deleted member 4644
The following images were taken with a Nikon D90 set to vivid and sharpening 5. It was on a Manfrotto tripod with a Cullman Magnesit 30 ballhead, indoors. The images were lit with a Nikon SB-600 flash and an incandescent light bulb in a fairly dark room. The leaf was in the center of the frame with the focal point near its highest tip @ 18 inches from the lens.
I will let the images speak for themselves. 100% crops from RAW using NX 2.0.
My conclusions:
1) The Tokina has consistently lighter exposures than the Nikon images. The Tokina even blows out parts of the images that are not blown out with the Nikon. The Tokina images have substantially less noise however.
2) The Nikon is clearly a little bit sharper at f2.8, but the images are almost the same at f5 and f8.
My conclusions:
