- Nov 25, 2012
- 12,065
- 2,768
- 136
After discovering one fill valve gasket leak in a toilet, I decided to check up on the other toilets in the house and found the master bedroom one was leaking from the tank bolts. I got around to that toilet today and discovered the only thing sealing the tank was the rusted out bolt heads and who-knows-how old washers. The tank bolts were rotted through and the tank was literally free to just lift off.
Now the time consuming part is upon me. The rubber and rust have both left residue and I've been trying a mix of both physical and chemical. My primary concern is getting enough residue off for the new bolts. From my experimentation, ammonia works...a bit too well. I got it on the flush valve gasket it and a load of black just immediately came out. I'll probably have to soak something and let it sit on the area.
The old gasket residue is stubborn and I'm tempted to used something like mass airflow sensor cleaner to release the material. I've also used some steel wool to try to make progress.
The remaining rust is stubborn as well and I know hydrochloric acid can bust through it, but it gives off fumes.
