The stuff they stock our bathrooms with is half-ply at best. It's so thin you can see through it. It needs to be doubled over at least 8 times before it is usable.
Why don't they just put decent toilet paper in? People would use less of it, so it would even out cost-wise.
The paper in my building is not only thin, but it's only about 3 inches wide. I thought there was some kind of standard toilet paper width, but I guess not anymore 🙁.
