To XP64bit or not to XP64bit....
Sylvanas
3,752
Well I have been trying to decide as to if its worthwhile to upgrade to XP64bit for quite a while. Its a free upgrade according to M$ is it worth it? I will be using it on my system in sig. I know that many drivers may be hard to come by but ATI, Nvidia (for chipset) and Creative all have downloadable X64 drivers, are they any good? Last I heard the Creative X64 drivers were still in BETA and I'm having enough troubles with Creative drivers anyway, so has anyone tried them?
Jeff7181
18,368
11
I've been using the preview edition for a while now off and on. It works pretty well. I wanted to trade in my XP Pro license at the end of this month before the offer expires, but a family member still uses AOL and it won't work on XP x64. He refuses to get rid of it, and for various reasons I have to keep it so he can use the computer... so I can't get XP x64 unless AOL creates a version of AOL that works on XP x64 in the next couple weeks.
biostud
19,957
7,050
to few drivers ATM and too little software that takes advantage of 64 bit instructions.
13Gigatons
7,461
500
The Pros:
The operating itself is greatly improved being built on Windows Server 2003 code.
32 bit and 64 bit apps run great.
The Cons:
Lack of drivers and big names refuse to produce drivers for popular hardware.
Almost no antivirus and firewall software.
Sylvanas
3,752
Ok thanks guys, I guess I can wait till theres more support for 64bit software/drivers.
ch33kym0use
495
64 bit software and hardware is mostly used with servers, not really too useful at home
however ive been using 64 bit software at home anyway
i used the creative drivers with XP x64, not bad on my systems
Some1ne
862
Yes, just not yet.
...and I've used the 64-bit nvidia chipset, graphics, and IDE/RAID drivers, and the Creative 64-bit drivers, and I had no problems with any of them. Yes the creative ones are still in beta (or were, last time I checked), but they worked fine on my system (I have an Audigy MP3+).
TSCrv
568
VERY big CON..... = the lack of any cd mounting software... talking about annoying, nearly 90% of my stuff is in ISO format, so now i had to clean my closet to find all of my cds.... dont go x64 untill alcohol 120% or daemon tools comes out with a x64 version
