Ok so we have adelphia cable and we had it hooked up through a linksys router/firewall thingy but the linksys crapped the bucket. Since I was hard up for some internet fun I went to target and bought the only thing they had which was a motorola router/firewall. Now the motorola has 4 ports for cat5 and also has wireless capability.
Here's our setup, the modem/router is downstairs in my parents office where they have 2 comps hooked up directly to the router. My room is on the other side of the house and I have 2 (sometimes 3) computers hooked up to a 3com 4 port switch (I think that's the right term...) which is then hooked up through a single cat5 cable to one of the ports on the motorola downstairs.
Now my question is, would I be better off getting wireless network cards for my secondary/tertiary boxes then running through a switch? My ping in CS runs from 70's - 150's in most servers and I'm pretty sure it was better then that before I put the switch in (when I had my gaming box hooked straight to the router instead of through a switch).
Is wireless the same speed as standard cat5 connections? What is a good wireless card to get? I have a little flexibility here because I can always use the cat5 I already have in place for my gaming box (if indeed cat5 is faster) and wireless for my internet surfing/utility box...
How is the software situation? Does wireless require a lot of software installation/config with windows xp or is it pretty much plug and play?
