I have a fairly new perfectly stable (so far) Dell Precision Workstation 340 (P4/256MB 2GHz w/ 1GB of RDRAM 800) that I've set up to do NLE video and Photoshop type hobbies. I've used all of the available bays now and would like to add at least two and maybe four additional SCSI drives to the system. I am also starting to think about all of the heat in that black clam shell Dell case.
In a previous posting I was told that the Dell mobo and power supply/connectors were not standard and it would therefore be difficult to move everything to a new case that has more room.
Questions:
1. Do you think that I should move to a new mobo & larger case (full tower) or should I just add a separate case for the pending SCSI HDD expansion?
(Is there something special on the "workstation" mobo worth keeping besides the Dell onsite warrenty that I wouldn't get with a DIY mobo?)
2. If I do move the P4, RDRAM, etc., to a new mobo, then which mobo would you recommend considering that I've never built before (although I was once a EE) and I might at times want to try to OC just for the pure fun/frustration of doing so? (Should I hold off for the new 533MHz fsb like others are?)
3. I would like to also hear any advise as to whether/when I should think about upgrading the P4?
Money is usually no object, except to my wife.
Thanks!
Questions:
Thanks!
