I have a Conroe E6700 core 2 duo working with a Gigabyte GA-965P-S3 motherboard, and 4 gigs of Corsair dual channel TWIN2X2048-6400C4PRO (DDR2 800).
My question is this: to achieve a faster machine, is it better to lower the CPU multiplier and raise the FSB? My quarry originates from the idea that a FSB of 350 with a x10 multiplier = 3.5 ghz, while a FSB of 437 and a x8 multiplier = 3.49 ghz which is roughly the same speed. Would the higher FSB cause my machine to run faster, or would my machine run at the same speed with both settings, that is considering both worked perfectly stable? I ask because I don't know or understand the technicalities of the FSB and its effect on the computer.
Thank you,
Brendt
Thank you,
Brendt
