To build a wireless RS232 system...
AznMaverick
I want to design a RF modem basically. It will take serial data and transmit the data through a walkie talkie with RF...how do i do this? i've been looking at RS232 transceivers...but that just looks like it takes TTL level and increases the voltage to RS232 levels...i'm confused...
How fast does it need to be? Check Linx Technologies. They have easy to use RF modules that take care of the wireless part...just need some level converters to make it all work.
