To all overclockers w/ Thermalright heatsinks...Please post your cpu temps for reference...
ferrarifreak93
339
I want to know if my NF7-S v1.2 motherboard is over-rating the cpu temps b/c i know many motherboards have inaccurate cpu temp diodes. Please post your cpu temp(idle and load - most interested in idle), case temp, ambient temp, cpu voltage, what model heatsink you're using, what fan you're using, and your motherboard model. Also, include what your cpu is overclocked at if it isn't in your sig. Right now I'm at 2305Mhz and only 1.7 volts but my temps are 36C case, 54C cpu, and 21C (70F) ambient. Thanks
FluxCap
1,207
cpu = 36c
case = 22c
ambient = 23c
slk-800a
YS-tech variable at full speed
overclocked from 1470 to 1750, prime95 for 9 hours and temp was 36
Abit NF7-S v1.2 like you
MoFunk
4,058
Originally posted by: ferrarifreak93
good, keep the responses coming...especially all SK-7 users
Full load 51c with sk-7 and generic 80mm fan
8RDA
XP1700+ 11x190@2090mhz 1.75v
My case cooling was designed around the Alpha PAL8045 so these temps are a little higher then I would like.
Batman5177
216
thermalright sk800 w/ panaflo 92mm h1a w/ as3
mobo: a7n8x
xp2100 @ 1.73ghz @ 1.6v
cpu = 32 idle, 38 load
xp2700 @ 2.185ghz @ 1.725v
cpu = 35 idle, 41 load
these are socket temps, the diode temps are 4 degrees higher.
am i supposed to read the socket or the diode?
loafbred
836
58
You caught me at a good time - I just removed and scoured my AX-7 and am using Cooler Master Premium paste for the first time. It seems to give about the same temps as Arctic Alumina.
Thermalright AX-7, Sunon 50.6 cfm 80mm fan
Palomino 2100+ @ 10X190 w/2.0v (set to 1.95v, but reads 1.98-2.0)
Ambient: 27C
System: 30C
Cpu idle: 40C
Cpu moderately loaded: 45C
Motherboard is Epox 8K5A2.
lundog22
1,201
1700+ 0310 WPMW
A7N8X DLX 2.0
SLK800U w/ Stealth 80mm
CPU at 200FSB x 11.5 @ 2.3Ghz , 1.7 Vcore,
Prime95 full load @ 54C/129F reading from Asus PC Probe utility
minendo
35,560
22
TBred 1700+ at 1912MHz on ePox 8rda with Thermalright AX-7/Panaflo L1A.
CPU: 45C Under Full Load
NesuD
SK7 with Y.S. tech variable speed fan at full speed. 3600 rpm
tbred 2100+@2.0Ghz 1.66 volts
39c idle
43c load running Prime 95
Jeff7181
18,368
11
SK-7 with cheap ass 4500 RPM 70mm fan
XP2500 @ 2100 (200x10.5) @ 1.750 volts
Temps right now...
Ambient room 20C
Case temp 20C
CPU temp under 100% load for over 30 minutes now 40C
CPU temp idle was 34C if I remember correctly
JamesM3M5
218
Thermalright AX-7, quiet temp-sensitive 80mm fan with Antec Silver Paste on 1600XP Palomino core at 166FSB:
Ambient 70F
Case 80F
CPU 116-128F depending on load
Just switched to Thoroughbred core XP1700+, same HS/Fan, will get temps once the box warms up.
The AX-7 builds up a lot of dust on the top where the fan blows down onto it. I have to clean it every month.
EDIT--BTW, that's one hell of an overclock on a 1700+! The Panaflow L1A doesn't flow that much air, so you should expect higher temps than others running higher speed/noisier fans.
Krueger81
4,196
SK-7
Load 52C
Not sure on idle it's never idle since I crunch SETI. It's an XP 2400+@2200MhZ (200FSB*11)
ASRaiven
17
NF7 1.2
AXP 2100 (TBB)@2200 mhz- 1.81v
SK7+NanothermBlue2+SF2 2600~ rpm
idle: 41
load- 48
alkemyst
83,769
19
SLK-800, PC Power and Cooling 80mm Silencer, Tualatin 1.4-S at 1.5 / 1.65 volts
low: 39C
ave: 42C
high: 49C
ferrarifreak93
339
I did want to make a database with all these temps for reference for others, but people don't post all information needed, like ambient temp which makes a BIG difference in temps :| However, thanks to all who posted - I should be able to find what is wrong with my temps now, everyone seems to have lower temps than me
Jeff7181
18,368
11
I've recently increased my clock speed again, back to 2.2 Ghz (200x11) with no change in temps.
Jeff7181
18,368
11
Keep in mind motherboards measure the temperature at different locations, and while the actual temp may be the same, one board may give a higher or lower reading than another.
scrubman
696
XP1700@(11x200)2.2Ghz@1.65V
Epox 8RDA+ C1 stepping
SLK-800w/PanafloH1A
temps -- Prime95@12hr cpu=51c case=39c
temps -------------- idle@ cpu=44c case=37c
