Tivo setup with no landline phone HELP!
Joyride
1,782
I just moved into a new apartment and to save the $20 a month for a landline phone I am going wireless.
Stupid me I decided to start from scratch and erase everything. Now I am trying to setup my TIVO again but it won't let me without a land phone.
Is there anyway around this or am I going to have to talk a friend into letting me use his phone just for the setup call.
HELP PLEASE!!
sillymofo
Banned
Aug 11, 2003
5,817
You can't. Even after setup, the shiet won't work. What you can try to do is get a wireless phone jack terminal, which you then will plug one into your friend/neighbour and one near your Tivo.
WoofyJr
277
Since u have series 2, it can be connected by by broaddband through the router and enthernet. I have it running by using the router, amazing fast than the phoneline. All you need is wireless router and wireless adapter to connect your tivo.
You can check tivo community.... They usuallyhelp you out.
GasX
29,033
HELP PLEASE!!
that call gets made every day to keep the data up-to-date. Looks like you just got a high-tech VCR...
edit: I stand corrected - you have a series 2
fs5
11,774
series 2 has an ethernet jack? :Q
I might have to consider getting one, but my current series one has 100 gb in it :(
I've been considering the ethernet mod though.
RossMAN
Grand Nagus
Feb 24, 2000
79,083
456
I thought Tivo Series 2 only has USB but it also has Ethernet?
That would be wicked awesome if we could hook ours up to the WiFi network.
iwearnosox
16,018
Not to sound rude by why did you even post?
cause i am rude
Because he's a nef that seemingly feels ATOT is his personal blog, like most nefs. (Speaking as a reformed nef myself.)
Ahem.
Is this just a regular SA tivo, or a directivo?
Joyride
1,782
I Have a D-link wireless router and USB wireless ethernet adapter hooked into my tivo.
Works like a dream when it can
bunker
10,572
I thought the usb ports were dead on the series 2 units?
EDIT: when I say dead I mean disabled now but put in for future use.
loup garou
35,132
um...no. Mine's been up and running with a usb ethernet adapter for about a year.
Alternex
Even a series one will work with a home lan w/ internet connection. I got a ethernet adapter for it and no longer need my home phone line
emmpee
1,100
a series 1 tivo requires a TivoNet (or whatever it's called) add-on card to add ethernet
a series 2 tivo has USB ports, with which you can use a USB nic
waggy
68,143
10
Yeah!
i just ordered a Series 2 Tivo! should be here in the next few days.
I dont have a landline. hope i can get it working with the internet connection (going to have it in my office so it will be near my router). oh crap im going to have to purchase a usb netcard. heh
slag
10,473
mines not hooked up through a land line or anything. Its modded to use a script called fixsub.tcl which fools the unit into thinking it has dialed out and made a successful connection. This is a directtivo though, not a regular tivo. The directtivo gets info from the satellite stream. I had to make this alteration to it because the room i am in has no phone jacks and I refuse to go buy a wireless phone jack just so my tivo can call out.
Slag
RossMAN
Grand Nagus
Feb 24, 2000
79,083
456
I thought the USB ports didn't work?
emmpee
1,100
Originally posted by: emmpee a series 1 tivo requires a TivoNet (or whatever it's called) add-on card to add ethernet a series 2 tivo has USB ports, with which you can use a USB nic
they work fine
I don't know about DirecTivo boxes, but standalone Series 2 Tivos have perfectly functioning USB ports. I *believe* that at one point they were non-functioning, but a Tivo software updated "turned them on" a WHILE ago (at least a year).
RossMAN
Grand Nagus
Feb 24, 2000
79,083
456
<a class=ftalternatingbarlinklarge href="http://www.tivo.com/4.9.1.asp#2" target=blank>they work fine</A>
Awesome, thanks for the linkage.
waggy
68,143
10
yeah thats what i read. I orderd a 40 hour series 2 tivo. figured with the USB ports i can hook it up with my router (need a usb netcard though). I just hope it is NOT hard to get working. I dont know a whole lot about Linux (it uses it right?) heh
