Titanfall 2 PC Details and System Reqs
Bacon1
3,430
1,018
http://www.titanfall.com/en_us/news/pc-specs/
Few benchmarks, not sure exactly what hardware (didn't see it mentioned but sounds like they are using the sys req hardware profiles) but looking like they are spending quite a bit of time on the PC version which is great to hear. Benchmarks they did provide show solid fps for beta.
Titanfall 2 PC System Requirements
Minimum
OS - Win 7/8/8.1/10 64bit
CPU - Intel Core i3-3600t or equivalent
RAM - 8GB
HDD Free Space - 45GB
GPU - NVIDIA Geforce GTX 660 2GB, AMD Radeon HD 7850 2GB
DirectX - 11
Internet Connection - 512Kbps or faster
Recommended
CPU - Intel Core i5-6600 or equivalent
RAM - 16GB
GPU - NVIDIA Geforce GTX 1060 6GB, AMD Radeon RX 480 8GB
DirectX - 11
Ultra 4K60
CPU - Intel Core i7-6700k or equivalent
RAM - 16GB
GPU - NVIDIA Geforce GTX 1080 8GB
DirectX - 11
Ken g6
Moderator
Dec 11, 1999
16,830
4,812
75
Also note what they consider "minimum":
Our goal for minimum PC specs on Titanfall 2 is that you can play at a 1600x900 resolution with most details turned on and average around 60fps.
So even some slower machines may be able to work at absolute minimum settings. I wonder if the game requires 4 threads, or if the Pentium G3258 will work?
TheELF
4,029
753
The only times games do not run,or do not run well,on duals is due to bad porting where they don't even compensate for the consoles start running games from the 3rd core or when they run things at high priority without compensating for windows task manager.
lehtv
11,897
74
What's "i3-3600t"? In google search it only comes up with reference to Titanfall 2 specs.
Why do they recommend a faster processor for 4K? As resolution increases, CPU becomes less of a factor, not more.
Yeh I think I'm just gonna wait for GameGPU, TechSpot and others to do their thing.
TheELF
4,029
753
'Cause...that's why.
(When you pay for an 1080 you can pay for a decent CPU,balanced build and all that. )
lehtv
11,897
74
Except that when you pay for a 1080 and a 4K monitor, you have less money to use on other components.
TheELF
4,029
753
Ah yes,that is the eternal struggle of us poor folks...more graphics or more CPU.
Red Hawk
3,266
169
They also went into detail on all the PC video options:
PC Video Options
  • Anti-Aliasing – None, TSAA, MSAA (2x, 4x, 8x)
  • Ambient Occlusion – Enabled, Disabled
  • Aspect Ratio – 4:3, 16:9, 16:10, 21:9
  • Brightness - Slider
  • Display Mode – Fullscreen, Windowed
  • Dynamic Spot Shadows – Enabled, Disabled
  • Effects Detail – Low, Medium, High
  • FOV – Slider
  • Impact Marks – Disabled, Low, High
  • Model Detail – Low, Medium, High
  • Ragdolls – Low, Medium, High
  • Spot Shadow Detail – Disabled, Low, High, Very High
  • Sun Shadow Detail – Disabled, Low, High, Very High
  • Texture Filtering - Bilinear, Trilinear, Anisotropic (2x, 4x, 8x, 16x)
  • Texture Quality - Low, Medium, High, Very High, Insane
  • V-Sync - V-Sync Disabled, Double buffered V-sync, Triple buffered V-Sync, NVIDIA Adaptive V-Sync, NVIDIA Adaptive Half-refresh V-Sync, Dynamic V-Sync
Other PC Features
  • Uncapped framerate up to 144fps (on a 60hz display with V-Sync Disabled you can run up to 144fps)
  • Fully remappable key bindings
  • Mouse acceleration enable/disable
  • Individual localization audio files to reduce download and installation size
  • Gamepad support with multiple configs and sensitivity options
  • Savegame and config stored in the cloud (video and control configs are editable .txt files!)
  • Voice and text chat in-game and in-Network
  • Multiplayer anti-cheat out of the box
So yeah, hopefully this will be a well handled PC port. No word on DX12/Vulkan support though.
LTC8K6
28,520
1,576
Headfoot
4,444
641
Titanfall 2 looks awesome. Way more interesting of a shooter than Battlefront 1, err I mean Battlefield 1. They actually are adding new strategic considerations and variety rather than making the planes slow and having horses instead of motorcycles/ATVs
