Tires Slowly Leaking Air
Status
Not open for further replies.
Wyndru
7,318
4
Recently, my tires started leaking air, all 4 of them. They are leaking very slowly, but each week I need to put about 15psi in them. I brought it to the shop, who cleaned the beads, checked the valve stem etc., but they are still leaking.
I called the shop, and they said that aluminum alloy wheels get "pitted" over time and begin to leak slowly, so I may need new wheels. Does this sound legit?
They are 2 different manufactured tires (front set are the winter tires), so I don't think that there is a common defect with the tires. It just seems strange that all 4 tires started leaking about the same amount of air at the same time.
radioouman
8,632
Yep, cast aluminum wheels are porous and they will start to leak eventually.
Chrysler had a problem with this in the 1990s and there wasn't much you could do to fix them.
AMDMaddness
2,406
Do your tires have those stupid bar codes that sit right on the bead and the outer edge of the tire? they should have removed those they are very commonly the problem
Wyndru
7,318
4
Pulsar
5,224
306
Any porosity in aluminum can be repaired using a simple epoxy. This is how manufacturers correct defects in heads and other cast aluminum components because, as other other people have pointed out, porosity is nearly unavoidable in any cast component.
Wyndru
7,318
4
Might be time to look for a new shop.
c3p0
Yeah it's actually not my regular shop, it's Midas. I normally go to this small shop near my job, but the owner that runs it has been ill, and his son can't keep up with the service so they are really backlogged.
I always get the shaft when I go to these corporate service centers.
Oh well, thanks all for the info, at least now I know it can be fixed, and I'll take it back to my regular place once I can.
lavaheadache
6,893
14
I would also check your valve stems. They are prone to drying out around the base and you wouldn't know it unles you wiggle it from side to side
Status
