Is it just me, or does it seem like there are a ton of new heatsinks that sure look cool, and some sure are big, but very few are much better than what's been around for a while. Can you say gimmicky?
Heat pipes are cool (no pun intended). But all they do is move heat from one place to another. They don't disipate heat into the environment at all. They are in fact, less useful than peltier coolers, imho. Why move the heat to another place where you will put a disipating element, when you can disipate it into the environment at the source, like the Zalman designs do.
Also, A ton of the new designs attempt to channel the air from the fan to blow across the fins. This doesn't work well. I know. As an Engineer, I've studied gas flow around fan blades. You'll just make noisier fans and slow down the air velocities. You are much better off utilizing the natural air flow around a fan, or redesign the fan, than rechannel the air movement coming from a fan.
I'd like to see more passive CPU cooling - like heatpipes to fined aluminum cases. This is one place where heatpipes actually really could be useful. Sure Hush Technologies makes systems like this - but I know it could be a ton cheaper and possible for joe-blow (again, no pun intended) to do. Just look at all the car audio amplifiers that have been using this technology for the longest time.
-Dave
-Dave
