Tire Poll - BFG, Goodyear, Dunlop, and Michelin
NTB
5,179
Ok, this time I'm a little more prepared :) I checked a couple of places today, and I think I'm going to purchase from the local Sam's Club. Here are the details:
Dunlop SP40s
65,000-mile tire
S speed rating
UTQG = 500
$43.52 each, 210.08+Tax installed
B.F. Goodrich Touring T/A Pro
70,000 tire
T speed rating
UTQG = 640
$55.04 each, 256.16+Tax, installed
Goodyear Allegra
75,000-mile tire
T speed rating
UTQG = 560
Michelin X-Radial
80,000-mile tire
S speed rating
UTQG = 740
$68.43 each, $309.72+Tax installed; 259.72 after $50 instant rebate
As sort of a side-note, I also checked out Sears, and they had the following:
Sumitomo HTR-H4
65,000-mile tire
H speed rated
UTQG = 400
Traction = A
Temp = A
$65 each, ~$385 installed
All tires except the Sumitomos were rated at A for traction and B for temp, I believe.
Tires are 195/70-14, and are going on a Pontiac Sunfire SE 4-door. I live in the midwest, so I drive in a little bit of everything - good dry weather, pouring rain, ocasional snow in the winter, etc.
EDIT: Please see the question in my most recent post at / near the bottom of the page!
Nate
Vette73
21,503
9
What is the treadwaer , temp, and traction rating of the tires?
Don;t buy a tire because of the name. They all make good and bad tires.
conehead433
5,569
901
Well those are all great tires, but I've had the best results with the cheap A$$ tires I bought from Wally World. Paid extra for lifetime rotation, balancing, repair. Cheaper by far than anywhere I've bought tires from. I think they sell Michellin if that's what you want.
BoomerD
66,618
15,010
Not a fan of Dunlops. Never had a set that rode or wore well. Don't like BFG's, although they do make a couple of decent tires for certain applications. Goodyears are decent for MOST applications, and Michelin possibly makes the best high-end tires for my particular uses.
So, that being said, what is the vehicle, how is it driven, and what kind of conditions?
NTB
5,179
Originally posted by: michaels
Damn what size are those, 10 inch??? That's cheap
14s. stock steel wheels on a Pontiac Sunfire SE.
Nate
NTB
5,179
More information added to the original post - hope that helps.
Nate
Captante
30,354
10,880
Out of your choices I'd go with Michelin... I'd suggest checking out Bridgestone too.
AMDMaddness
2,406
Toyo FTW oh wait do they even make tires that small? I have tried just about all the name brands out there I love my toyo tires every set I have ever owned has been above avg.
NTB
5,179
hmmm... 2 each for Dunlop and Michelin, and one each for BFG andf Goodyear. Keep 'em coming!
Nate
Pabster
16,986
BF Goodrich FTW
Although I might suggest a set of Traction T/A over the Touring T/A (probably about $10 a tire more) as here in the Midwest we have snow in the winter :p
NTB
5,179
Originally posted by: Pabster
BF Goodrich FTW
Nobody has the Traction T/As in stock. I tried ordering them through Walmart, and they were going to take ~3 weeks to get here (to HQ no less :p). I'm going to drive home for the holiday weekend, so I need them sooner than that.
Nate
NTB
5,179
Just got off the phone with my dad - I e-mailed him essentially the same info that's in the first post, and he said to go with either the BFGs or Michelins.
Nate
NTB
5,179
Question (even though everybody seems to dislike goodyear):
After digging around on the internet for a while, I've seen in several places that the Walmart-only Goodyear Viva Touring is supposedly the same as Goodyear's Regatta 2 - and that tire has some fairly good ratings on Tire Rack. Anybody have any idea if this is true or not?
Nate
bctbct
4,868
Nate
Ive had the regatta 2 and it was a very good tire. Smooth and quiet.
PAB
Banned
Dec 4, 2002
1,719
Y'all know that BFG = Michelin, right?
I'd get the Michelin X's just because for $10 more, you get the instant rebate. Plus, you wont have to tire shop for a long time!
