Tips for driving stick/manual?
Crono
I don't know how to drive stick shift, but I want to learn. I'm considering getting a manual transmission car - possibly a Scion FR-S, or possibly a Mazda 3 w/manual - very soon (as in a few days or sooner). I know someone who can teach me how to drive stick, but I'd also like to get some tips/advice from any of you experienced drivers out there.
Any tips or advice?
This is how I downshift when braking into a corner
Do you have to drive it home or are you able to get someone to do that for you? That can make a big difference on how soon you'd actually be able to get it home since if you're on your own, you'll probably be sweating bullets if you live in a busy area/dealership is far from home.
Otherwise, standard manual driving tips, start in a parking lot, get a feel for the clutch and when it engages and how much you can play with it before it is completely engaged/stalls. This will be different between cars. Also the physical difference between gears can also get you (to stall) sometimes. When I was learning on a friends Civic, the gears were further apart so when I was test driving my speed3, I kept going into 3rd thinking I was in first a lot.
Also don't rest your foot on the clutch at any time other than changing gears. Same is true for the gear shifter. Reverse can be in different places depending on the car.
If you are uncomfortable with the car rolling back when you release your foot off the brake, try to avoid roads with any heavy inclines for a while until you're more familiar with your clutch and/or find a deserted hill and have it.
Reverse is not as bad as most people say, the main trick is to feather the clutch and it actually helped me get used to the clutch, conceptually, better than getting off in first.
Remember to lift off the gas when changing gears.
Best way though is to have that person show you how to do it. Depending on who has to drive the car home once you get a hold of it, you may want to know what it feels like to drive it and to ease any nerves you have about stalling in the middle of the street with your new car on the way home 🙂 though that will mainly happen with time.
There's probably more stuff but you'll get more concise questions once you actually drive it.
Any tips or advice?
Practice.
If possible, find a large area, parking lot, forest preserve, whatever and just practice starts and stops.
You'll be surprised how fast that you will pick it up...
Best of luck!
Uno
Use the clutch.
Yeah in all serious, it's just practice more or less.
That and don't ride the thing, good way to wear them out over time.
When you first start practicing, in a large parking lot of course, first learn to slowly let the clutch out and get the car moving without using the gas pedal.
Most cars can do it, and it gives you a much better idea of how and where the clutch engages in relation to the pedal position.
I am sorry to hijack here but question for you seasoned vets: I'm a new (2 month) stick shift driver, and I'm doing fine except for going from 1st to 2nd. Every so often, as I go from 1st to 2nd, I will feel a 'vibration' / almost like it's about to grind (the shifter), until I move it back into neutral, then to second. I'm pressing down all the way on the clutch, so I have no idea what it is. Any ideas?
ONLY from 1st to 2nd does it do this. Thanks
Noob, they have cars that do that for you nowadays.
My only tip is that you don't really need to start in 1st gear most of the time*.
*If you're not trying to get anywhere fast, like to the next stop light.
Best advice right here.
Learn the clutch before you complicate it with using the gas to take off quickly. Pretty much any car should be able to get rolling off idle while feathering the clutch. Reverse should be easy because it is even "shorter" than 1st gear on many cars, which puts more torque to the wheels at lower rpms.
I went through this last year - bought a '13 Focus SE 5 speed. I had a friend of mine drive it home from the dealership. We stopped in an empty parking lot on the way home and I had a ~10 minute lesson no how to get started.
Luckily I have an automatic truck I could drive to work while I learned how to drive the manual. The first month was a bit tense - I never realized how many hills there were around me until I got the stick 🙂
When I initially got it I went out later at night, around 10pm, and drove around my neighborhood. Put it in first, practice getting it rolling, stop and do it all over again. Stalled a couple of times but figured it out quickly enough. Once you can get it moving from a stop consistently then you're pretty much good to go.
A year later I can drive it fine but I still struggle with making it perfectly smooth on every shift. I tend to let off the clutch too fast so I've been working on slowing that down. Now that I know enough to drive it every day I'd really like to attend a class or something to get some better instruction on some more advanced techniques. I've never had instruction other than that 10 minutes with my friend.
I definitely don't regret it though - it's a lot more fun and "interactive" than driving an automatic. Plus it opens my car options up to a whole new set of possibilities. I'm seriously thinking about getting an ST now which is something that would've been completely unavailable to me a year ago.
I used to have a 1970's Camaro with a 3 speed unsynchronised transmission I loved att.
One of the greatest memories of having it was letting my female cousin who had been driving a little old Toyota at the time drive it at a family get together and watching her eyes almost pop out of her head at the time when she popped the clutch like she was used to and spewed gravel all of my Aunts well manicured lawn at the time.
I was sitting in the shotgun seat and laughing my ass off big time.
Learning to use a clutch is one thing, and it does vary from vehicles.
She was used to driving a clutch in a little 4 banger, the Camaro freaked her out big time, at first, but once she got out of the driveway she started having some fun with it.
I miss that Camaro, wish I still had the SOB.
I bought my Mazda3 without knowing how to drive stick. It kept stalling on me, until I realized I had hand brake on. One thing I don't like about the car is the hand brake is super weak, I think it only goes to one wheel, so in SF going up the steep hills, the car will roll back with hand brake on.
I got lazy in my old age, have the 5 speed auto dual gate in the Mazda 3 here 🙂
I just leave it in auto though, 99.5% of the time.
Maybe you are lifting up on the clutch too soon while trying to get it into 2nd? That or shifting too fast? Some gears don't like to be rushed. 2nd to 3rd in my car has a tendency to do that if i try to move it there too quickly.
Only driven a manual vehicle once (dirt bike) but didn't spend enough time to really get the hang of it. I think it would be easier in a car though.
The sheer amount of traffic and unsynced lights in Toronto makes driving standard a tiring affair. I would still like to learn though.
My folks bought a five speed Toyota Celica when I was a junior in high school. They brought it home of course and we lived out of town on a country road. Dad wanted to show me, but after he gave me a general idea of what I needed to do I asked if I could just figure it out on my own. It took me about ten minutes to get it backed up and heading down the driveway. Once of the road I killed it several times, but after about thirty minutes I was kind of getting the hang of it.
Basically, I'm one of those people who get nervous learning a new thing if someone else is watching. Leave me along and let me work it out. After a few weeks of driving it I was like an old pro - better than my dad according to mom. 😉
The Saginaw 3-speeds used in the 2nd-gen Camaros were synchronized on all gears.
Back in the 1950s and early 1960s, the Saginaw 3-speeds lacked syncronization on 1st only (2nd and 3rd had synchros), but by 1970 all three gears had synchros.
ZV
driving a manual isn't very hard. Getting smooth at it to the point where no one can tell its a manual VS an auto is another thing.
Many people just ride the clutch a LOT when they learn to drive. If your willing to learn then its just a matter of minutes/hours til your good at it.
Hehe, I had to learn driving automatic when I rented a car in the US.
Basically just press the clutch when switching and then gently let go once you have changed gears. When you feel that the engine and wheels are in sync release clutch completely.
What exactly is that statement supposed to mean? Granted, you might have to "learn" something with driving an automatic, but the rest of your post is WTF.
Ive been driving my mt accord since last august and only thing i need is to learn rev match downshifting... too much of a pussy to try it but i always realize when i need/want to do it..
http://youtu.be/C1UB306t-98
Like that guy.. lol
