Tips for clawhammer overclocking
HeXploiT
I'm going to be running a clawhammer 3200+ on an Abit KV8 Pro and attempting to overclock the system as much as possible. It's been awhile since i did any oc'ing and i know that the 130nm clawhammers generate more heat than the 90nm newcastles so i'm wondering if there's anything i should be weary of when getting started or if anyone has any tips for oc'ing the clawhammer. Also i need to find an updated source that can help me understand all the latest bios featurs and options that the KV8 and newer bios' offer as i want to tweak the bios as much as possible without damaging the system. Any links are appreciated.
KV8 PRO? Is that KT800 or KT880? If its only the 800, you're basically fvcked when it comes to OCing. 240 is the max HTT w/o a lock, I could never get the 7:1 and 8:1 dividers to work with my MAX3.
Volts wise, IDK. I ran my clawhammer with a venus 12 and a 80MM tornado on max, and Temps were 63C with 1.9vcore. 1.7 was enough to get me to 2.4GHz stable, though.
Granted this one was a 3903, one of the first ones off teh line, so yours might do better.
No locks for that, but there are dividers, I believe. Unless one came out after April 05. I could never get the 7:1 to work right, but then again, I was trying to run 10x266, stupid multi's weren't unlocking...
