Well like I said, if the engine is making awful noises and shakes badly like something is wrong, then you're probably loading it down too much. I hate to say this but it isn't necessarily an apples to apples comparison as every engine design is different but I think it's safe to say this Aveo can probably handle low RPM shifting. It's true I've driven some cars that just couldn't handle low RPM shifting but those were typically older model vehicles that had less sophisticated computers, etc. You shouldn't make absolute statements like "you absolutely cannot shift before 3K RPM" just because your POS porsche can't...
You might want to take a read on this thread about your crappy volvo.
http://www.matthewsvolvosite.com/forums/viewtopic.php?t=62742&p=323058
My sister in law owns a Volvo S60 which is a 5-speed transmission and it will happily shift even as low as 1500 rpm while the transmission you mentioned is a 4-speed. So not only could your transmission have a problem with not being able to shift early (the thread I linked to mentions 3K rpm shifting problem) but you may not be aware of the shift points.
I have to ask, do you actually own any vehicles with some form of variable valve timing? Or are all of your vehicles 15 year old+ euro trash vehicles?
Ahh, and now you're accusing my cars of being crap. Should have seen that coming.
Please show me where I said "you absolutely cannot shift below 3,000 RPM." If you're having trouble, here's some help, I never said that. In fact, of the two of us, you've made far more absolute statements. All I've said is that in a car with as little power as the Aveo has, and an engine that is clearly designed to make power at higher RPM (the 3,800 RPM torque peak) it's ridiculously stupid to upshift at 2,000 RPM. That's a heavily qualified statement that applies to a very limited subset of vehicles. You're the one who's making categorical statements about "all" vehicles.
The link about the Volvo simply proves what I said. That the shift maps are hard-coded and do not adjust to driving style.
The specific point at which the transmission shifts is not fixed (it will vary with engine load and throttle position), but the map it uses is fixed. The shift points in that link mentioned by other drivers correspond with the minimum upshift points I've seen in my driving and equate to upshifts occurring between 2,400 to 2,600 RPM depending on the gear. Didn't you say that there were "no cars" where you couldn't make an automatic shift below 2,000 RPM? Seems like your blanket statement doesn't fit here. Shocking that.
Again, I'm not saying that you can't have the engine below 2,000 RPM. Please try to get that through your head. I'm saying that if you treat 2,000 RPM as a redline on a car like the Aveo you will be getting rear ended by bicycles because the acceleration you'll get is best described as "glacial" and it's not a plausible strategy for going up hills.
I'm sure you'll come back again and argue about something that I didn't say because you're basically fleabag or LOUISSSS, but I'm done here.
ZV
