- Jun 24, 2001
- 24,195
- 857
- 126
OK, my notebook (M11x r3) requires an external optical drive which has been nothing but trouble. When a rip can take hours something almost always happens before I can finish, like the drive gets disconnected or tugged or dropped and I have to start the rip all over. Also, sometimes I forget to check "Large file size" in Handbrake, the result is unplayable, and I end up wasting hours (have to start all over). I think the best thing would be to get the content off the disc as quickly as possible and then process that rip into a smaller files size. What is the fastest way to get the main content off the disc where the bottleneck would be the maximum disc/drive transfer speed and not processing/encoding?
What I'm usually trying to do is make something suitable for streaming to various media devices and watching in Full HD. In the past I often ripped in HD with huge file sizes and transcoded to SD for phones and such with limited storage, but I recently got a 1080p Galaxy Note 3 and want to carry some 1080p content (especially with my MHL adapter). The current 7GB+ per 1080p movie is not going to cut it: I have a 64GB microSD card and 32GB internal memory and I can fill it all right up with surprisingly few movies or TV shows.
Long story short: I'd like to know how to get reasonable file sizes for feature-length 1080p movies (preferably under 4GB for FAT32). Should I even be using Handbrake? Two-pass encoding? What? I'm sure my files are a lot bigger than they need to be.
