Ambient2012
Hello everyone!
This is my first post here, I've browsed for a while, and figured it was time to register and introduce myself because I wanted to get some feedback on the computer I'm going to be putting together. I haven't put together my own PC for quite some time, so I wanted to get some feedback and advice on the parts I'll be getting. If you have any better ideas, or can think of something that would be more cost effective, let me know!
Here's what I plan on getting:
ASRock Z68 Professional Gen3 LGA1155 Intel Moetherboard
Intel core i7-2700k Sandy Bridge 3.5GHz Processor
G.Skill Ripjaws Z series 32GB 240-pin DDR3 1600 Memory
XFX FX-797A-TNFC Radeon HD 7970 3GB PCI-E 3.0 Graphics Card
OCZ Agility 60GB SATAIII SSD
Seagate Barracuda 1TB 7200 RPM Hard Drive
OCZ ZX Series 1250W PSU
Lite-On Blu-Ray Burner
I plan on getting a second HD 7970 at some point.
I'm also going to do liquid cooling with a 3x120mm radiator, a CPU block, and a full-coverage GPU block. Will also have additional case fans, and memory cooling fans.
My main goal is overclock-ability. I was originally going to get one of the i7 extreme edition processors, but it seems like the 2700k can perform almost just as well with proper overclocking. I'll also be overclocking the HD 7970. With the liquid cooling, I should be able to push it pretty far, correct?
If I can cut costs anywhere and get similar, if not better, performance, that would be great.
Anyone have any comments, advice, tweaks, additions, questions, etc?
Thanks!
Thanks!
