Here it is: I recently switched to DSL and I have a CAT5 terminal panel (1 slot in/6 slots out) running cat5 through out my house. I want to take the incoming cat5 line and tip it with an RJ-11 to run to my modem, then run cat5 from modem to patch panel, and from the wall jack to my wireless router. I have every thing I need, I have even tested to figure out which cable on the panel goes to the jack I want to use (since the lazy contractor decided not to label them!). I'm just not sure which pair to tip. I assume it would be the blue pair because that's how I've usually seen the wiring done when running digital telephone lines. But i wanted to get some one else's perspective.
