Tiny 3-pin Connectors
Dznuts007
629
Been trying to find some 3-pin connectors where I can connect some wires to a circuit board. it's approximately 4mm by 6mm and the pin spacings are about 2mm apart. Know anywhere I can find em? Been googling all day long but haven't been able to find a good store for these.
Zepper
18,998
A pic of the thing would help, but if you're talking about the fan header type connector, that is the Molex KK type with 0.1" (2.54 mm) spacing. Or if you're talking about the type used for front panel and front ports, those are standard 0.1" spacing header connectors. http://www.Action-electronics.com is my source for lots of connector types.
And Mouser.com carries a huge array of connectors.
.bh.
