Timing belt question, is every 60k/3 years accurate?
RossMAN
Grand Nagus
Feb 24, 2000
79,093
459
I called my local Honda dealer who said according to the owners manual it's 7yrs/105k.
$699 includes parts and labor :(
Budmantom
13,103
As long as it's a non-interference motor run it till it breaks ;)
My Pathfinder doesn't have a belt or chain so it "never" needs to be replaced.
funboy6942
15,368
418
It based on time and miles because weather can play havoc on the belt, drying it out and making it brittle even with low miles, and miles because rotation will wear it our rubbing up on the water pump, idler or tensioner pulley.
ive seen belts go 150K and 10 years, I seen belts go less then a year because of a manufactures defect, if you don't have a clearance free engine OP you willing to take the risk?
Scarpozzi
26,392
1,780
Some car manufacturers actually have timing chains. They are often made of nylon, but tend to last longer due to less stretchiness.
I would change it around 75k to be safe. You don't want your timing belt to break.
Having said that, if you buy a car with 100k on it, you might want to ask the previous owner if they changed the timing belt. These days though, belts last longer than they used to and the timing belt is usually pretty thick.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: IGBT
..after all these years why don't they replace them things with chains.
Chains require an oil supply to keep them lubricated. They also are noisier and transmit more vibration to the valvetrain.
Belts are smoother and quieter, as well as simpler to engineer, with a tradeoff of requiring replacement more frequently than chains.
Neither belts nor chains are absolutely "better", they simply involve different trade-offs.
ZV
funboy6942
15,368
418
ZV
Not to mention a chain lasts almost forever and dealerships need you to come to the shop often ;)
My 88 Firebird with a timing chain you cannot hear. Lots of older Caravans used chains and you couldnt hear them as well. Its all really BS, IMO, and just something that needs replacing to make people come to a shop is all. If people are given a choice between a little bit of rattle or a $800-$1500+ timing belt replacement bill which you think they would take?
BornStar
4,052
Originally posted by: Mermaidman
Hijack:
What about timing chains? My Olds has a timing chain.
Gasp. Thread Hijacker.
what year/mileage.
Yeah, I bad.
2003 Olds Aurora, V8.
I've got a 99 Aurora and I don't expect to ever have to worry about the timing chain.
I got the timing belt changed on my 92 Camry for what I believe to be the first time in 2005. It had 120k miles on it and was still running fine.
Feb 10, 2000
30,029
67
Originally posted by: redgtxdi
Also..........yours is a non-interference motor, so no worries about valvetrain damage.
Honda + 4-cylinder = Interference with only one exception, the 2.0 litre SOHC, which was not used in the '02 Accord.
http://www.theautoshop.com/timing.html#HONDA
Asterisks indicate interference design.
Is it possible to break a timing belt without damage on an interference engine? I actually owned an '84 Accord with 1.8L engine and assumed it was non-interference (I actually broke the timing belt on the freeway in Sausalito, and it did no damage), but according to that guide I was wrong.
Staples
4,953
119
Originally posted by: Linux23
Our '02 Accord is 4.5 years old (25,500 miles) and the timing belt hasn't gone out yet.
Wow Ross, you don't drive much do you?:Q
Not much but it is more than me.
And I'd like to know, if you buy a used car, how are you supposed to know about when it change things? Are there symptoms you should look for? And why is preventative maintenance really necessary with the timing belt? Will the car blow up if it snaps? With most things, I figure a tow truck bill would be the only added cost over getting it fixed before it snaps.
OS
15,581
you can justify using that cost for trading, doubly so since you get more for low mileage. :p
honda says you should change the belt more often for extreme cold/heat conditions but you probably don't see that.
fbrdphreak
17,555
Ross,
You may want to hunt around for a local shop instead of a dealer. You may have the culpability of a large dealership to hold accountable for problems, but you pay through the nose for it. Call around to a lot of different shops, maybe orienting towards the ones that advertise "imports" or "Hondas" as their focus. Talk to them over the phone first: I've found that if someone is rude or is not very helpful over the phone, chances are you won't want to bring your business there. I've shopped for numerous types of automotive service in my area and found that to be nearly universally true. Then go check out the place. One of the things I noticed at the place I finally selected to service my Subaru is that they had letters and notes tacked to a wall from their customers expressing gratitude for the excellent work they had performed. Their place was overall well kept and when there was a minor issue with my service, called me into the shop to show me.
The issue I had to shop around for my Subaru was replacing a CV axle. The dealer wanted something like $200-300 to replace just ONE CV axle, not including the ridiculous cost of parts as well; it would've been over $800 parts and labor to replace both from CV axles. I ordered my axles $115 for both (remanufactured, same as the dealer would have used), and the Subaru shop rate was $115 labor per axle to install. MUCH cheaper and they did a great job.
Shoot me a PM if you have any questions :) And how do you like your ThinkPad???
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
It's theoretically possible, it's also possible not to have enough damage to stop the engine from running, but it is very, very rare.
ZV
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Most used cars still have manuals... They will tell you the proper intervals.
On most modern cars, the engine is an interference design, which means that unless the valves are timed precisely, the pistons will collide with the valves. Typically this results in damage to the valves, but this can also result to damage to the pistons and cylinder walls as well (the latter occuring most often when a piston-valve collision results in the head snapping off the valve and bouncing around inside the cylinder). If the timing belt snaps, except in rare, near-miraculous, instances, the pistons will strike the valves and cause very expensive damage.
ZV
RossMAN
Grand Nagus
Feb 24, 2000
79,093
459
Originally posted by: fbrdphreak
Ross,
Thanks for the tip. Fortunately I have a local mechanic who specializes in imports. So I called asking for his advice and he recommends 60k which is around 10 years assuming we continue to average 6k/yr.
I'm probably going to sell it. I shoud have ordered the other model which offers a 14.1" WXGA :(
IGBT
17,976
141
..does the Toy.4.0 and 4.7 L truck motors have chain driven cams or belt??
