Time keeps changing to wrong time (1 hr behind) on a workstation.. help? (on domain)
Mizugori
496
I have a workstation here that always sets its time an hour behind. If I manually change the time, ten minutes later it has changed back again... I don't know where this is coming from because the server has the correct time, and before someone says this, daylight savings time is correctly set so that's not the problem. net time reveals that it is (supposedly) getting the time from the server.... ???
any help would be greatly appreciated. thanks!
Mizugori
496
i appreciate your desire to help me but think about it, if the time on the server is correct (what i want it to be) then obviously it is in the right timezone and DST... also if the time on the server is not the same as the time on the workstation in question, it's pretty clear that the server is not giving the workstation the wrong time...
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Set the time correctly and disconnect from the network.
That will give you a clue if the reset is internal or external.
armstrda
426
You need the Windows patch from last year that adjusted the DST from last week to this next week.
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Bingo :)
MedicBob
4,151
I am looking around for this solution too. 30 machines on a domain, 3 are incorrect. Servers are correct, NTP pulling correct time, and 3 of 10 identical computers are incorrect. DST patch loaded via WSUS and is installed, time zones correct on domain and clients, etc...
If I figure it out I will let you know.
Chadder007
7,560
Make sure that checkbox is checked to use DST also....
If they are Windows 2000 machines, you have to install a 3rd party patch to fix DST.
MedicBob
4,151
LOL found it... DST 2008 patch refrenced above was refused by all 3 machines. Applied patch and all is right until next year.
Thanks for the tip with 2000 though.
