Tiger 133 Cooling Methods.....Availability of Arctic Cooler?
Robbed
54
Anyone know where I can get an arctic cooler, I've looked everywhere for a couple to no avail. The predicament I'm in is that I have a tiger133 dual mobo with PIII-700e fcpgas on abit slotket3s. The space between the slotkets is about 35-37mm, and I want to get these puppys up to 933. The only cooler I can find that is not only small but good is the arctic circle, which I can't figure out how to buy. Also, if anyone knows a setup where the fan is on the side of the heatsink at an angle, or any sort of duct setup that would fit in here, let me know.
rob
mechBgon
Oct 31, 1999
30,699
How about a pair of these with the fans mounted on the sides? As you can see, the fins are oriented in the proper direction relative to the slocket. http://2cooltek.safeshopper.com/1/109.htm?570. You could also make a bit of ducting to ensure that as much air as possible goes through the fins, using light cardboard or plastic.
edit: you might have to slice some off with a hacksaw if it doesn't fit. I have a Tiger100 and have wished many times that the blasted Slot1's were further apart :(
Mikewarrior2
7,132
That's the original Panaflo ORB cooler at all. The articooler is a new heatsink(unfortunately, yet to be released) from Agilent.
Mike
Robbed
54
blain, that's a little taller than the arctic cooler so it won't fit for me. AND there is no way to mount that to a fcpga
rob
damien6
1,256
Hardocp had a link to some German vendor selling them in (duh) Germany but as of yet it still isn't available in the states. I think they're expecting them sometime in the end of August or early September.
CamaroGuy
235
Here's what I snip of what I just posted in another thread:
>Call Avnet @ (888)-715-4684.
>They are taking preorders at $26.00.
>This info came directly from Agilent.
Retail availablity is set for mid- to late-August.
-CamaroGuy
