[THW] Review Samples vs Retail R9290x boards(large differences)
What materials are they using?
Is amd's aluminum? Nvidia Copper?
I would also imagine there are some heatpipes hiding inside the nvidia cooler.
Can you say the same about Nvidia when they've sent binned chips to reviews like these ~
HTML:
www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_780_Ti/30.html
Double standards I guess are a common feature of Nvidia's viral marketing & also widely practiced by their supporters 🙄
Where does it say its a binned chip?...or are you just guess and spreading FUD?
I also found this interesting from Kyle @ [H]
So, when we compare performance we run the 290X in quiet mode, but when we compare noise we run the 290X in uber mode. Just like it reminds Kyle of posters on [H], it also reminds me of Ryan's review of the 290. nVidia is working every angle they can to plant seeds.
Sure they are.....the truth is probably a case of Chinese whispers....
A densely-packed fin arrangement can provide very effective cooling, but only with high static pressure from the fans (which usually translates to high RPM and lots of noise). This is why you'll often see this in server heatsinks: saving space is important, and no one cares how much noise the fans make because they are in an isolated room somewhere.
Having a wider fin spacing means theoretical maximum cooling is less, but you can get decent results with low airflow. This is why you usually see wide fin spacing on products designed for quiet, passive/semi-passive cooling, like the Thermalright Macho and the Arctic Accelero S1 Plus.
Nvidia seems to have calculated that wider fin spacing would provide enough cooling for their ~250W cards while allowing for lower airflow that keeps noise levels down. For whatever reason, AMD went with a more tightly-packed fin arrangement, which means the fan has to spin at higher speeds to attain the static pressure needed to blow the hot air out.
The Nvidia blower looks to be about the same diameter, but is taller (as are the corresponding heatsink fins). This is probably hurting AMD's reference design a lot. Nvidia can get the same airflow at lower RPM.
I'm not sure Nvidia is gaining anything in terms of performance by using a metal blower instead of plastic (though it unquestionably looks better). Virtually all case and CPU fans, even premium ones, are made out of plastic, and this works fine. The same goes for the shroud: switching to metal/plexiglass is an aesthetic design win, but probably doesn't affect performance.
Could AMD fix this cheaply? Who knows. The shroud and blower impeller are probably injection molded, and creating new molds is not cheap at all.
As for copying Nvidia's design, I'm not sure they can do that. Nvidia almost certainly doesn't have a patent on the functional aspects of the blower (there's nothing new or innovative about that) but they may well have a design patent on it, given the amount of time and effort they put into development. Honestly, AMD would probably be better off just making a deal with one of its AIB partners to use their cooler in the reference design. Any of the third-party coolers (with the possible exception of XFX) are better than what AMD is cranking out.
blackened23
It seems to me AMD and NVIDIA have a much better understanding of how the enthusiast $400+ market works and what it responds to than either of us.
From what I see the enthusiast market responds to Performance and Price/Performance.
If that wasn't the case, NVIDIA with a graphics card less noisier that consumed less power and came with a three AAA game bundle wouldn't have dropped the price of the GTX 780 by $150.
Not sure what you are trying to say there, but the 780 was always going to fall in price when it didnt compete with the 290x, so they could bring out Ti into that price bracket....
It doesn't, but:
[repost of http://forums.anandtech.com/showpost.php?p=35699366&postcount=58]
On the matter of review samples:
One reviewer said in his youtube 290X cooler (yes, cooler - because that was the main point of review) video review, this:
Quote:
"I don't know if I got just a bad [290x)] sample [...], but one thing I will say is when nvidia send samples out to the press, they were so [profanity] blatently cherry-picked its unbelievable [...] so I'm little bit underwhelmed that AMD have not been [..] this stuff aswell"
(not going to post link, time stamp @34:40)
I just did a recount on the number of fins, 42 for AMD vs. 34 for Nvidia, so I guess I must have been drunk the first time I counted. AMD's fins are about 25% more dense.
Great silicon but crappy cooling? I don't get who would want this stock cooler. You gotta either wait for custom boards or replace the cooler with a custom one immediately.
The stock cooler has been universally reviewed as being crap. It's not in the same league as Nvidia's blower. Sad considering it's a good card.
The same will go with the 780 Ti though, all the custom PCBs will be clocked faster and I'm sure will do at least 5% more than the base cards, if not more.
Every buyer should be aware that reference boards are only good for those who want to do watercooling, as most water blocks are reference board only.
All this hoopla is moot as most people will be waiting for the custom PCBs anyway!
And why would AMD care about copying the ornamentation? The function is what they need, and if the functional elements aren't patented, they should use it.
No heat pipes, they are both vapor chamber coolers. On the Nvidia card, notice the rear of the card with the aluminum fins? It intakes air from the rear whereas the Radeon only pulls from the fan. The air intake looking holes are actually fake on the 290x. Nvidia uses a Delta blower fan which has a ton of CFM. If AMD had a rear intake on the fan, it may have reduced temperatures about 5-10c depending on your intake fan situation.
That's also for exhaust. The blower draws air in from the center and blows outward. It doesn't have a front and rear per se. it blows out in all directions.
After reading through the page below and the one following it describing how NVidia achieved the acoustics with its current cards, you will realize that just copying the design wouldn't serve any purpose unless AMD used all the exact same components and laid them out exactly the same on the PCB.
My Personal Crusade: Acoustics
Improving the ergonomics as NVidia has takes significant engineering and testing. To the point that NVidia hired people specifically to address these issues. Something AMD is clearly not interested in investing in, instead choosing to let AIB makers foot the bill. Neither side is really right or wrong, but it is should be obvious why NVidia products cost more.
Nice post. I really want AMD to look into their reference blower designs next time around because alot of people do prefer this type of cooler. It makes the overall product that much more attractive imo. Im sure the R290 would still be an attractive buy if it was priced at $449 with a much capable cooler.
One thing that is somewhat surprising to me atleast is that no one yet has attempted to do a three slot "blower type" solution!
HIS does a 2+ slot blower. Works pretty well. Much quieter and improves cooling by ~12°C over the reference cooler. Their dual axial fan design is better though.
The design could easily be beefed up with more fin area by just making the fins taller. Super easy.
The dual intake on the blower is just genius.
Nice but the "better design" seems to actualy blow
the air mainly inside the case , if the card is not covered
there s no way that its exhaust has lower flux resistance
than the upper part of the card , if AMD did use such
a "solution" they would had no trouble being on par or so
with their competitor noise wise.
Edit : So are these Nvidia cooler covered or are they
left uncovered.???...Question to the owners.
According to hardware.fr the VRMs are much cooler
on the AMD ref than in the 780ti.
Arcording to hardware.fr, the 290X reaches 98.6C on their thermal cam. Ouch! Its obvious what card is poorly designed, and its not the 780ti. And hot VRMs is nothing new, remember 125C on HD4xxx and HD2xxx? And 100C+ on HD6xxx?
290X
GTX780Ti
Weird is that it s measured near the exhaust , we see clearly
the chip area being at a lower temp.......
VRMs are made of silicon like the chip and thus have
not a higher resistance to temperature.
Military specs are up to 125°C and silicon is specified
at 150 to 200°C max temperature depending of the processes
and kind of devices.
Edit : is the cooler of your card covered.?.
You all seem to ignore the fact AMD would need to redesign the whole power area of the card in order to fit a large enough fan like we see on the 780 ti. Fitting an Nvidia style cooler on the current 2-slot layout simply wouldn't be possible.
LOL, hearsay from 1 reviewer....you must be right!
Nice threadcrap. 😕
As pointed out, ironic considering the article is about 1 reviewer.
So 98.6C in general is of concern (on the board), yet 125C on VRMs isn't of concern. I'd say the broad statement 98.6C is of concern is a little broad without any rationale.
