Hello im getting laptop with thunderbolt3 port and id like to often connect to my desktop monitor/keyboard/mouse.my goal is to have keyboard,mouse, and monitor connected to a hub and be able to come with my laptop just connect one cable to be able to use laptop with desktop monitor, keyboard, mouse.
I see there are usb-c hubs to connect everything together i think to make this work?My desktop is kinna old lga1366 without any type c connector or even usb 3. It has:
EDIT : i just got word I won't be able to connect my monitor to my desktop via USB-C even if i get a PCIe USB-C adaptor. thoughts on best way how best should i go about it? what do i need to buy to connect to my monitor, and mouse with keyboard? less cables to connect to laptop the better
my monitor has dvi and vga inputs, mouse and keyboard are usb. desktop gpu has vga,dvi,hdmi outputs.
laptop has:
1 HDMI™ 1.4b output Port (with HDCP)
2 Mini DisplayPort 1.3
1 Thunderbolt™ 3 / USB 3.1 Gen 2 combo Port (Type-C)
1 USB 3.1 Gen 2 Port (Type-C)
4 USB 3.0 Ports (USB 3.1 Gen 1) (1 x powered USB port, AC/DC)
thanks
- 2 x PCI Express x16 slots, running at x16 x16
(The PCI Express slots conform to PCI Express 2.0 standard.) - 1 x PCI Express x4 slot
- 1 x PCI Express x1 slot
laptop has:
thanks
