- Sep 29, 2000
- 70,150
- 5
- 0
1) Should I loosen (not remove) the center nut holding the strut together before removing the strut from the vehicle? I know it's normally done with the strut out of the car, but I know that sometimes nuts can need a lot of torque, and it would be easier to at least loosen it (a quarter turn) before doing anything else.
2) Do I grease parts typically when replacing (I'm replacing basically all the parts, including bearing, new rubber seats, too).
3) How can I avoid having to get a front end alignment (it's a newish minivan)? Apparently when taking the strut from the knuckle, there is some way to keep those bolts aligned in some fashion to save me having to re align.
