Diagrafeas
This is how i imagine the ideal slot placement on a z87 motherboard...
Top-->Bottom
Slot 1: PCIE 2.0 1x
Slot 2: PCIE 3.0 16x
Slot 3: N/C
Slot 4: PCIE 2.0 1x
Slot 5: PCIE 2.0 16x (4x Eletrical)
Slot 6: PCI
Slot 7: PCI
PCIe 1x , 4x , PCI will share lanes, so you should have the option to CHOOSE what to use...
4x + PCIs (none PCIE x1)
4x + one PCIE x1(top) (none PCI)
4x(@2x) + two PCIE 1x + two PCI
Alternative with two PCIE 3.0 Slots..
Top-->Bottom
Slot 1: PCIE 2.0 1x
Slot 2: PCIE 3.0 16x/8x
Slot 3: N/C
Slot 4: PCIE 2.0 1x
Slot 5: PCIE 3.0 16x (8x Electrical)
Slot 6: N/C
Slot 7: PCIE 2.0 16x (4x Eletrical)
PCIe 1x , 4x will share lanes, so you should have the option to CHOOSE what to use...
And for the back Panel
Bottom-->Top
6 Sound Inputs+Outputs
HDMI , Displayport , Optical Output
DVI-D , DSub
2 USB 2.0 , 1 LAN
2 USB 2.0 , 1 PS/2
4 USB 3.0
Or you could remove D-Sub, Use DVI-I and try to fit two eSATA ports.
Internal Connectors
6 SATA 6 Gbps
1 USB 3.0 Header (2 Ports)
2 USB 2.0 Header (4 Ports)
Top-->Bottom
Slot 1: PCIE 2.0 1x
Slot 3: N/C
Slot 4: PCIE 2.0 1x
Slot 6: PCI
Slot 7: PCI
Top-->Bottom
Slot 1: PCIE 2.0 1x
Slot 3: N/C
Slot 4: PCIE 2.0 1x
Slot 6: N/C
Bottom-->Top
DVI-D , DSub
2 USB 2.0 , 1 LAN
2 USB 2.0 , 1 PS/2
4 USB 3.0
Internal Connectors
6 SATA 6 Gbps
