- Oct 20, 2009
- 1
- 0
- 0
hey guys,
I am going to be building my first water cooled system. I need desperate help
I have read, read and re-read tons of threads. I have been doing as much homework as possible. I spoke to someone who builds these setups and he swears I only need one loop for my setup. When you goto a doctor with a problem, you often get a second opinion..I need one from you experts
I am going to be cooling the following:
Core i7 920 (will be overclocking as much as possible on this CPU)
(2) XFX Ati 5870's (will NOT be overclocking these to MAX, just a nice overclock on each)
Asus Rampage 2 Extreme (Northbridge/Southbridge and Mosfets) using the Bitspower BLACK FREEZER along with the EK-Mosfet ASUS X58 KIT
This is what I am being told will be sufficient:
Dual DDC 3.25 pumps running with a Watercooling eK dual pump top
Feser X-Changer 480mm Xtreme Performance Radiator (with 4 Scythe fans)
EK-Multioption RES 250 Rev 2 Reservoir
Swiftech APOGEE XT Ultra Extreme Performance Water Block
(2) 5870 Full coverage waterblocks
all of the above with 1/2" tubing
Silverstone TJ07 case
Now in MY mind from all my reading the CPU and the NB/SB on the Asus Rampage 2 Extreme runs pretty hot, especially if I am going to be overclocking it pretty high. I don't think ONE loop with all of the above is going to get my temps cool. I am not looking for the cheapest setup, I am looking for the BEST COLD setup. I do not want to have to re-do things in a month.
I definitely would have to run the CPU first in the loop and I can only imagine the water being fairly hot after that, and then hitting the NB/SB and Mosfets to me would just be so hot...AND THEN still have to cool the 5870's (even without a massive overclock)
Will this Res/Pump/Radiator really do the job in one loop?
Should I run (2) loops with the CPU, NB/SB/Mosfets in one and the 5870's in their own much smaller loop?
from what I am being told the 5870's will not be creating enough heat to justify needing two loops, and it will run nice and cool with everything in one loop.
I really appreciate any responses.
