- Dec 1, 2000
- 181
- 0
- 0
I got an old Dell here, its a Dimension XPS T500 which is a P3 500. The harddrive in this computer is formatted so there is nothing on it. The only other IDE device is a Plextor that I planned on using as the drive to install the OS. We got nothing but the vid card in there which is a Voodoo3 3000 AGP.
Well we get video cause I see the bootup screen. It does a ram count. It properly identifies the harddrive and cd drive. Then I get this message:
System Configuation Data Updated
ERROR
0271! Check date and time setting
Press <esc> to continue or <del> to go to setup
Well when I press ESC the screen goes black and just sits there. And if I hit DEL it will just sit there. I need some help.....
ERROR
