This statistics problem is insanely hard.
ManBearPig
9,173
A student suspected that the average cost of a Saturday night date was no longer $30.00. To test her hypothesis, she randomly selected 16 men from the dormitory and asked them how much they spent on a date last Saturday. She found that the average cost was $31.17. The standard deviation of the sample was $5.51.
a. At a = 0.05, is there enough evidence to support her claim?
b. At a = 0.10 is there enough evidence to support her claim?
c. Use a 95% confidence interval, to test the student?s hypothesis?
d. Use a 90% confidence interval, to test the hypothesis?
e. How do your conclusions in a and c relate? What is the relationship between b and d?
I found the critical value, the z score and z test value for 0.05 (for 0.1 itd be the same format), but ive got no effing idea how to find out if there is enough evidence or not...wtf does that mean? i assume i have to compare two of the numbers, but which?
THANKS
p.s. here are the values in case someone thinks im lying:
H0 = µ = $30
H1 = µ < $30
Z = (30-31.17)/(5.51) = -0.2123
Z test = (30-31.17) / ((5.51)/v16)) = -0.8494
Hacp
13,923
That was years ago lol. I hated business stat, especially those Z tables.
Leros
21,867
7
The test is invalid because it does not guarantee that all the men she selected went on dates. Therefor the sampled data does not have any relevance on the question being asked.
And seriously, don't you need more than 40 samples for the formulas to work? Isn't there something about needing more than 40 samples?
ManBearPig
9,173
haha, id love to be able to get away with that but im sure shed freak out.
Jadow
5,962
Jadow Date:
"Hey babe let's split a 6 piece bucket and get it on!"
results greasy sex FTW
Soccer55
1,660
4
THANKS
H0 = µ = $30
H1 = µ < $30
First, you have your Z score formula wrong. You have (u - x)/sd when it should actually be (x-u)/sd [where u is the population mean and sd is the standard deviation]. Next, determine if you have a 2-tailed, right tailed, or left tailed test and determine the critical values for the 0.05 and 0.10 significance levels. To finally arrive at an answer for a and b, you need to take your test statistic and compare it to the critical values for the 0.05 and 0.10 significance levels. The test statistic being less than or greater than your critical value(s) will tell you whether or not you have enough evidence to reject the null hypothesis. For parts c and d, there are formulas to calculate the confidence interval limits, so you can just look those up in your textbook and it should be fairly straight forward from there.
PS - You will also want to determine whether this involves a standard normal distribution (Z-scores) or if you should use the T-distribution (T-scores).
rgwalt
7,393
Sorry, I took real math classes, like calculus and differential equations.
:D
J/K, stats is a tough subject. I never wanted any part of it.
blinky8225
564
First, you should be doing a two sided test.
H0: u == $30
H1: u =/= $30
Let your test statistic Z = (16)^(1/2) (X - 3000)/551, where X is average of the cost of the dates.
a) if you are going to test at level of significance 0.05, you will reject H0 if Z > 1.96 or Z < -1.96. This is not the case. Accept H0.
b) if you are going to test at level of significance 0.10, you will reject H0 if Z > 1.645 or Z < -1.645. Again this is not the case. Accept H0.
c) if you want to use a confidence interval of 95%, you find that the interval for the mean u is from 28.4701 to 33.8699. 30 falls into this interval. Again, accept H0.
d) if you want to use a confidence interval of 90%, you find that the interval for the mean u is from 28.9040 to 33.4360. 30 falls into this interval. Again, accept H0.
e) it turns out that A & C are the same test. B & D are also the same test.
So no, there is not enough evidence to support her claim using the above tests.
dbk
17,685
10
H0: u == $30
H1: u =/= $30
wow..nicely done brah
blinky8225
564
H0: u == $30
H1: u =/= $30
Thanks. If only I had questions like this on my statistics test last week, I might have actually passed.
<--Math major at Duke
ManBearPig
9,173
are you freaking kidding? i thought she meant no more than instead of no longer, thats why i wasnt getting anything. CRAP.
thanks a lot guys!
ManBearPig
9,173
can anyone point me in the right direction for this one please?
A film editor feels that the standard deviation for the number of minutes in a video is 3.4 minutes. A sample of 24 videos has a standard deviation of 4.2 minutes.
a. At a=0.05, is the sample standard deviation different from what the editor hypothesized?
b. At a=0.10, is the sample standard deviation different from what the editor hypothesized?
ManBearPig
9,173
alright, ive got no effing idea how to do the chi squared one. i looked at the chi-squared distribution but i dunno how to apply this problem to that! damnit. at least its not worth tons of points.
blinky8225
564
Brah, you're lucky that I'm bored tonight. The statistic X = n*v'/v has chi-squared distribution with n-1 degrees of freedom, where v' is the sample variance, and the v is the actual variance.
n = 24
v' = 4.2^2 = 17.64
H0: v == 3.4^2 = 11.56
H1: v =/= 11.56
You simply need to pick two values c1 and c2, where you reject if X > c2 or X < c1. You pick them so that P[X > c2 or X < c1] = a. You just have to put in random numbers for c1 and c2. I normal pick them so that they are centered around the mean of X, which is 23 in this case. There's other ways to do this, and you should follow the convention your book or professor uses. With my convention, you will reject H0 for both levels of significance 0.05 and 0.10. It's possible to pick an interval such that you would accept H0 at a = 0.05, though. You're pretty much always going to reject H0 at a = 0.10, though.
So, the director is probably wrong.
ManBearPig
9,173
n = 24
v' = 4.2^2 = 17.64
H1: v =/= 11.56
sweet jebus, i have to read that over a few times. i dont think its the same way as our professor taught us, but then, well...she didnt really teach us. thanks man.
blinky8225
564
Yeah, it's possible the question meant for you only to do a one-sided test, which would make it a lot easier. The question isn't very clear in this case. In the one-sided case, you would use:
H0: v =< 3.4^2 = 11.56
H1: v > 11.56
You would still reject H0 at both a = 0.05 and a = 0.1 in this case.
KayGee
268
You can't use the normal distribution if the population standard deviation (sigma) is unknown. The general rule is to use the t-distribution if the sample size is less than 30 or sigma is unknown. Also, this is a two-tailed test.
