- May 17, 2007
- 8
- 0
- 0
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
This will be used in connection with a Samsung 5265, Onkyo 605 powering Polks in 5.1 and some other odds and ends. The main thing this unit will be used for is its movie and music capabilites as well as surfing the web.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Hoping around $800.
3. What country YOU will be buying YOUR parts from.
Good ol USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I am not a fanboy. I do believe in quality.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Nope, fresh build.
6. IF YOU have searched and/or read similar threads.
Building is a nonissue. I have a very highend PC for gaming. This unit will not be used for that and I have never built a HTPC before.
7. IF YOU plan on overclocking or run the system at default speeds.
No OCing on this unit obviously.
Thoughts, suggestions, tips? Thanks all!!!
Hoping around $800.
Good ol USA
Nope, fresh build.
