- Dec 11, 1999
- 16,716
- 4,674
- 75
Now that Haswell is out, I'm looking at putting together a build around it in the next 2-4 weeks. I have a general idea about most of the hardware, but cases and cooling are not my thing.
Case:
...And cooling
I'm planning to get an i7-4770k, overclock it, and run it continuously at full load for distributed computing. I'd like suggestions for the best air-cooling systems to do this that will fit in the case described above. I realize the small case size may limit my options. I don't want water cooling because (1) it's inefficient, and (2) there will be periods in the summer when I don't run the processor hard to keep the room cool. I'd like screws, preferably with a backplate, and not clips. I'm considering buying this from Micro Center and having them install it because I hate installing thermal paste. Also, de-lidding is not gonna happen.
The best case I've seen so far is:
Fractal Design Core 1000 micro-ATX 16.54x6.89": http://www.newegg.com/Product/Produc...82E16811352009
But it's discontinued and doesn't support a lot of drives.
The second-best case I've seen so far is:
SilverStone PS08B micro-ATX 6.61" x 14" x 15.75": http://www.newegg.com/Product/Produc...82E16811163223
But it has the graphics card tabs sticking out.
I also think Haswell may need better cooling than either of these can provide.
So, what do you all suggest? Or did anyone make it through all of that?
Case:
- Need 16.5" (length) x 7.25" (width) or less. Height doesn't really matter, but small is nice. Up to 8.5" wide is acceptable if the case has feet at least 1cm high that fit the 7.25" width.
- Need to accept at least one 3.5" drive, one 2.5" SSD, and one DVD drive. Would like space for at least two 3.5" drives and a 5.25" DVD drive with the SSD.
- Need space for at least one single-slot low-profile card. Would like space for two video cards if possible. One can be my single-slot low-profile GT430. But an ITX case would be acceptable.
- Would like the video card section to be bumped in, rather than have the tabs sticking out. My current case has the tabs stick out. The problem is that, when inserting a large video card, I can't easily get both the tabs at the bottom of the video card past the motherboard and get the side tab past the edge of the case and into the section where it sticks out. This has twice led me to scratch motherboards with the tabs at the bottom of my GTX 460 video card, and is the primary reason I want a new case. But, if the case doesn't accept big, dual-slot video cards, this might not be an issue.
- Should be portable. Carrying handle, maybe?
- Would like at least half of the top (7-8") to be flat and not an air vent. But this may be negotiable.
- Would like to pay $100 or less. Could pay more, but wouldn't like to.
- Would like a positive-pressure case with an easily cleanable intake filter. But I've lived with the opposite of that (negative pressure, no filter) without too much trouble.
- It would be nice if case accepted a standard ATX PSU. But I wouldn't mind too much if it doesn't.
- Noise dampening would be nice, but isn't a big concern.
- Will buy from Micro Center or any well-known online retailer.
...And cooling
