- Feb 4, 2009
- 35,862
- 17,401
- 136
Oil I got is the same weight 5/30, I know synthetics can leak more but fortunately the blower doesn't leak much.
Apx 20 year old Techumshei engine.
That will work fine but if you find due to its age that it's burning a lot of oil or rattling a lot then you might switch to 10W-40. Synthetic vs dino, the extra expense of synthetic isn't warranted on a 20 year old small equipment engine but otherwise it'll work fine.
Would it be the same if the blower engine were 2 cycle and not 4?
2 cycle oil, ignore the newer 50:1 mix ratio recommendations and go with 40:1, then 30:1 as an engine gets wear (doesn't take long for the smallest consumer grade lawn equipment/etc, a few dozen hours) low ash synthetic.
If the richer mix ratio disturbs one's environmental concerns then it's time to switch to a 4 cycle.
Fixed that for you.2 cycle oil, ignore the newer 50:1 mix ratio recommendations and go with 40:1, then 30:1 as an engine gets wear (doesn't take long for the smallest consumer grade lawn equipment/etc, a few dozen hours) low ash synthetic.
If the richer mix ratio disturbs one's environmental concerns then it's time to switch to electric.
You know they sell pre-measured bottles of 2-stroke oil. Mix it in with 1 gallon of gas.
Fixed that for you.
