Think I finally found the right way to use both Flip 3D and an Expose clone
archcommus
As you probably know Vista comes with Flip 3D, so to tab between windows you can either use the old style Alt-Tab, or the new 3D Win-Tab. Both have their advantages: for quickly toggling between only two applications, Alt-Tab is better, whereas to get a better visual of everything you have open and to thumb through that stack, Flip 3D is better.
However, awhile ago I came across Switcher, an excellent free application written by Bao Nguyen that allows Mac OS X Expose-like functionality on Vista along with the ability to customize almost every part of the experience (and even two other viewing methods if you don't like Expose). Anyway, I like Expose, and definitely see its advantage over Flip 3D: no parts of windows are ever obscured, and everything can be seen immediately without thumbing through anything.
For awhile I played around with both methods trying to figure out which I wanted to stick with, I couldn't decide. I found that in different circumstances I preferred one over the other. Finally, I think I've sorted it out and decided on a good way to use both.
I realized that Alt-Tab/Flip 3D and Expose are inherently different methods of switching between windows and shouldn't be tried to be used for the same circumstances. Whereas Expose shows every window for you to choose from laid out next to each other, Alt-Tab and Flip 3D give you a stack or list to thumb through, a stack that you can see the order of plainly. Whenever you want to use the keyboard to thumb through applications, this is the preferred method, since with Expose it's not obvious which window is "next," and even with something like giant numbers to indicate this, it's still awkward to keep hitting tab and be randomly jumping through a big pile of windows in front of you.
However, when you want to use the mouse and not the keyboard, "thumbing" through windows is not the way to go. It's better to see what you want, and select it. In this case Expose is the preferred method.
So I have it set up like this: when I want to use the keyboard, I use Alt-Tab or Win-Tab. When I want to use the mouse, I hover over the bottom right corner of the screen by the clock, and Expose activates just like on a Mac. I click what I want and I'm done.
This was a long post to describe what seems like a pretty simple thing, but it's interesting to investigate such things about using a UI effectively.
What are your thoughts?
Or you could just hold down alt/win tab and click on the window you want?
I don't use alt-tab or flip 3d. When on Ubuntu I don't use the expose clone. I find it much quicker to just click on what I want on the task bar. The only time I end up using alt tab is when I'm in a game that's full screen.
That would work, but usually when I want to use the keyboard, I don't want to reach for the mouse, likewise when I'm sitting back in my chair just using the mouse, I don't want to reach for the keyboard.
Yes, usually just going for the taskbar is the quickest method, but when it gets crowded, especially when many windows are for the same app, I find these new fancy GUI methods helpful. Alt-Tab/Win-Tab is useful for quickly switching on the keyboard, and Expose is very convenient for picking among many windows with the mouse.
It was a bit annoying having Expose activate when I went to the bottom right of the screen, for situations when I went there quickly for some other purpose and didn't mean to activate it, so I turned that off and replaced it with something even better - middle click. I realized I don't really use middle click for anything else, so in Switcher I set it to globally activate Expose. It's very convenient, and even works from within Remote Desktop sessions, so it's an easy way to switch out of an RD session into another program running on my local computer.
