Thick Laptops are faster than slim ones?
MrVon
I've seen Very thick Dell and Hitachi laptops, but no idea if they actually got more juice than slim ones?
Theoretically if its bigger then they probably fit more stuff in it, e.g. faster motherboard/cpu.
My main concern is to buy Laptiop that is close to desktop by performance. Its for house use only i just like to be mobile if needed.
My other concern for ultra thin laptops is cooling are thin laptops have sufficient cooling to be on 24/7 under constant heavy load?
Below are just example images to give idea what i talking about (this mostly military and police laptops), i speaking of regular laptops.
OR
VS
Sheninat0r
515
The two "thick" laptops you linked to are that way because they are for use in very active environments where durability trumps performance. The Dell Adamo, on the other hand, was engineered to be a Windows MacBook Air killer - exceptionally thin and light, but weak.
If you want a thick, beefy laptop take a look at the Clevo X7200. An i7-980X (yes, desktop processor) and dual Fermi should make it beefy enough, no?
Generally speaking though, a higher-performing laptop will have to be thicker, so you are quite correct - your examples were just a bit off.
boran
1,526
It surprises me that the Clevo even has a battery. Those desktop replacements often skip that too.
Anyways, keep in mind that a high performance laptop has to be cooled and that heat has to go somewhere.
Consider getting a desktop + cheap laptop for on the move.
Blain
Check out this Compaq "Portable".
A company I used to work for back in the late 80's produced the plastic case parts and screen for this unit.
If bigger = higher performance, this "portable" should have been a rocket.
corkyg
Elite Member | Peripherals
27,370
240
"Thick" is primarily for ruggedness. And, with more internal space, it is p'ossible that better cooling would permit a faster CPU. But, that is not a rule - just a possibility. Remember, . . . all generalizations are false . . . including this one. :)
MisterDonut
920
Unless you work on-the-go, I'd go with a desktop + small laptop. Something with Optimus like the ASUS UL series makes for a great portable machine. Of course, this is in reference to Nvidia Optimus and not Apple Optimus (<- HAHA).
DaveSimmons
40,730
670
And a desktop will be much thicker than any of those laptops -- so it's bound to be fast! ;)
MisterDonut
920
AFAIK, the MBP is not faster than any P4 system. Took about 5 minutes to open WC3 on a P4....still can't get it to open in a Mac...:D
MJinZ
8,192
It's a gigantic failure, that's what the Dell Adamo really is.
For monstrous engineering, see Sony Z series. Core i7 Quad Core and dedicated graphics in a thin, light 13".
http://www.sonystyle.com/webapp/wcs...0151&langId=-1&categoryId=8198552921644570897
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
Then you're doing it wrong, Warcraft III, much like many, many other (almost all save Warcraft 1 and Diablo 1 I think) were made dual OS, Windows and Mac OS (9 for older, X for newer)\
Edit: Mfenn beat me to the punch.
MJinZ
8,192
Nah, Sony Vaio Z are all dual core with 4 threads. Even engineering couldn't stuff a quad into that sleek body. :]
Oh you're right, I'm thinking of the HP Envy 14.
The actual chip and socket for the i7 720qm is probably the same as the dual cores, so it's just matter of heat at this point I'm guessing.
