A few weeks ago, I bought a Justcooler P-8000 HSF.
It's supposed to come with a 80mm fan rated @ 38CFM, 0.15A, 28dBA and 2800RPM.
Today, I finally got to boot up the new system and try the heatsink out.
When I first turned the system on, I was surprised to hear quite alot of noise coming from the fan on the heatsink.
But this can't be, because the fan was rated at 28dBA and that was definitely not 28dBA I was hearing.
On the fan monitoring bios menu, it indicated that the fan was spinning at about 4000RPM - 4600RPM , where it should've been spinning at 2800RPM as rated. I rebooted the system and checked the figure couple of times more, and got the same result.Then I stopped because of fear that the fan might draw too much current from motherboard and damage the fan header.
Imagine a 80mm fan spinning at 4500RPM and making a hurricane noise..
Anyways, no wonder it was making all the noises. So I checked out the sticker on the fan, and It was written as 0.42 A, where the speification on the back cover was written as 0.15A!!
Now I'm thinking that they put a wrong fan on the heatsink. Can this be possible though..?
The fan sticker clearly says "Justcooler" brand name..and the model number of the fan is MGT8012YB-O.
Frankly, I don't want to send back the heatsink and fan, because it's just not economically sound to spend the return shipping just to check/change the fan.. and I don't want to take out the heatsink from the motherboard, risking to crack the core.
Maybe I can send the fan only, but what guarantee is there that the supplier will replace it.
Can you guys please tell me what options I have, and recommend me the best solution for this problem..?
