Thermostat Question - 5-wire system, 6-wire thermostat
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
My friend is replacing a 5-wire thermostat with a 6-wire programmable thermostat...
Pic
Here is the picture of the 6 wire thermostat I?m trying to rewire to a 5 wire system.
Basically, I need to figure out how the Rc/Rh on the new system match up to the R/O wires of the old system.
VirginiaDonkey
1,704
make sure you bought the right type programmable thermostat. some are for heat pump only, some are for gas heat, heat pump air
xrax
341
I went from a 6 wire to a 5 wire thermostat. The 6 wire had W-O-G-R-C-Y labels. The 5 wire has G-Rc-Rh-Y/O-W/B-Y1. Y1 is for a heat pump. G went to G. Y/O went to Y. O wasn't hooked up. R went to both Rc-Rh (jumper). W went to W/B. The C meant power, but it can also mean compressor by my directions.
Generally G means fan. R means heat and cool relay. Rc means cool relay, Rh heat relay. Y/O means A/C compressor. W/B means heat. Without seeing the original thermostat and the instructions for the new it is hard to determine.
Rubycon
Madame President
Aug 10, 2005
17,768
485
O is usually the reversing valve solenoid on those pesky heat pumps. :)
Oh and the R line is the hot side of 24v - touch this to G and your blower will run, for example.
As always, RTFM. :p
And KISS works too. (T87F forever!)
