Thermochromatic dye in water cooling systems
s2kpacifist
108
Here's a thought: Have a thermochromatic dye (I made this up and don't know if it exists) in the water of a water-cooling system that changes its color as the heat in the water increases or decreases.
There are photochromatic dyes that react to sunlight, but the have one major flaw: they cannot withstand UV light because they change their chemical structure when excited by the energy of UV radiation (and I have never heard of that type of dye in a water solution except for ink).
It would be amazing if they could get the dye to glow as well AND change color instead of break down :)
However I could be mistaken and they might have all of this in some mod posted on the 'net already.
