- Mar 26, 2009
- 1,543
- 0
- 76
Thermaltake WATER2.0 Performer Review
By: Brandon Harrison (Brandonwh64)
Though Thermaltake is no stranger to water cooling products, this is one of the first lines of closed loop liquid cooling systems. With the release of this series of closed loop coolers, Thermaltake has strived to bring large improvements to the hassle free liquid cooling solution. In this review we will be doing visual inspections as well as benchmarking to its competitor. Please feel free to ask any questions you may have on the product.
Unboxing
The box was well packaged and very protected with all of the components in their own individual packages. The whole package is tucked in an egg carton style cardboard container.
Specifications of the Thermaltake WATER2.0 Performer
the specifications of the Performer are similar to the Corsair H50. The radiators are identical in size. The pumps are not alike. The pump on the Performer is estimated ¾ inch in height while the H50 is estimated 2 ¾ inch in height.
Contents:
Back Plate (AMD “AM2/AM2+/AM3/AM3+”, Intel “775/1366/1156/1155/2011”
Retention Rings (AMD “AM2/AM2+/AM3/AM3+”, Intel “775/1366/1156/1155/2011”
Mylar
Grommet x4
Screws (Fan mounting) x8
Plastic Components Top x4 (AMD/Intel)
Plastic Components Bottom x4 (AMD/Intel)
Screws (CPU Block Mounting) x4 (775/1366/1156/1155/AMD)
Screws (CPU Block Mounting) x4 (2011)
Retention Clip
Washers x4
Fan Y Cable x1
120MM Fan x2
WATER2.0 Performer Unit
