- Oct 30, 2004
- 192
- 0
- 0
between the two (with pros n cons weighed out), which would be the better choice? the chip im using will be a 3500+. i will most likely overclock to a comfortable extent. thanks
Originally posted by: BW86
venus 12.
comes with a better fan
speed is adjustable
why dont you just stick with your stock hsf?Im at 2.55ghz and im doing fine with it. But if your on a budget i would get this:
http://www.newegg.com/app/View...=35-118-108&depa=0
Almost the same price as the thermaltake but so much better cooling and quietness.
