ThermalTake Tsunami Case Question.
hugejazz
I am building my new system as we speak. This is my first time using a TT Tsunami and Im having trouble figuring out the power supply connections for the 3 fans.
The rear fan's is connected to a set of 4 wires (yellow, black, black, red) and the manufacturers labelled it "For power supply". I figured that they connect to my PSU, but it also splits into another connecter (second white thing).
My question is: How do I connect my 3 fans from my case to the PSU? and is there a connection which i have to make to connect the mobo and the case fans?
Right. Plug only one of them into your PSU. The other one is only if you want to plug something else in your PSU using the same wire, pretty much like a Y cable. About the mobo connections, you should have another wire coming from the fan, pretty thin; that one is for RPM monitoring, only optional. If you want to use them, you have to plug them in specific sockets in your motherboard, probably labelled as FAN1, FAN2, etc, located around the mobo.
