Thermaltake Tower 900 White Edition Tempered Glass Modular (Most AWESOME case u'l evr c!) $229.99
mindless1
8,733
1,746
Meh, the geek in me thinks that's really cool but the adult in me just wants a small midtower I can hide on the side of my desk and forget about, like the dozen odd cases I already have so they're FREE.
There are some oddities though that would take it off my short list if buying a case.
1) Crazy amount of perforations everywhere. I want a central front intake ONLY and fine filtration panel behind that. A clogged up dusty system looks even worse with case windows.
2) Motherboard rear I/O mounted on top with cables sticking up vertically? It's not only ugly, it will put extra strain, possibly too much on smaller connectors like mHDMI unless you make some kind of cable support system to take the strain off.
It's kinda like ATX was designed with thought put into it and deviating from that is usually a negative, takes more work and expense to get a diminishing improvement.
jackstar7
11,679
1,944
This looks like the eventual successor to my FT-02 unless Silverstone steps up with something to compete.
funboy6942
15,362
416
I like the cable management around the top and out the back so you can showcase your guts, unlike a full glass side panel that if you really want to show your guts, cus you cant really if you dont want to show your wires cant really if the pc is sitting sideways facing a wall, have then wires off the side, making it look ugly, you can with this case from all angles, showing off everything. So thats a plus for me, and kinda reminds me a little of a popcorn machine in a way as well, and I use mine a lot for watching movies too, so disguise it as one for the fun of it :O
funboy6942
15,362
416
Like mine I have now, I like showing off my innards, but Im also stuck showing off my wire mess in the process doing so :(
BUTCH1
20,433
1,769
TBH I just don't like this, even if it was only $100. It looks like a stereo-rack and a computer case had an illegitimate child.
funboy6942
15,362
416
OH man you guys just dont see it do you??? This case has it all man! It can hold any size hard drive, fans, coolant, air, mobo, looks retro, but then again modern, I can see dvd drive, br drive, hell cd drive, or fan header/temp, or eq, or lcd screen playing Mario, or in the case behind that, I see a 16:10 monitor going in the mother fuc.......(SHUT YO MOUTH!!), I mean come on peoples, this case is the case of all cases here to show off ur stuff :D My mind is blown as to what all I could do with it, or most peoples if they could afford it, I cant, someday I will, someday :O
