That's a 6000 rpm 12v fan, I don't recommend connecting it to your mobo. It can be done but you run the risk of burning out the header. Just daisy-chain it to a 4 pin molex. 😉
instructions will tell you to use the 4pin molex connector and it will come with the adapter so no need to buy anything else if you plan to buy this fan.
Thanks for the replies. I wanted to use the 3-pin connector instead of using a 4-pin adapter because I suck donkey balls at organizing the wires so I wanted to have as few wires as I can.
