OK, found my answer. Apparently, when I took out my old power supply, I removed the trim ring from the rear that holds in the power supply. Sure enough, I looked at my old power supply and realized that the ring was attached.
As Home Simpson would say: D'oh
Gear:
- Antec 850 computer case ** Edit: Antec SX-840 case.
- New Thermaltake 480 watt power supply
Issue:
- The newer power supply is of a newer format. The mounting holes do not line up with the pre-drilled holes in the back of my case that held the old power supply. Actually, the new power supply is a bit smaller - and nearly fits through the power supply hole in the back of my Antec case.
Question:
- How are these power supplies supposed to be mounted in older cases with larger openings for the older-style ATX power supplies? Does an adapter exist? Or, would I need to purchase a newer case to properly "fit" the power supply?
Thanks!! 🙂
Gear:
Issue:
Question:
Thanks!! 🙂
