Link Review Rebate link.
$46.55 - $15 MIR = $31.55.
Specs:
* 3.5-inch USB 2.0 eSATA hard drive enclosure for 3.5-inch SATA hard drives
* eSATA transfer speed of up to 3 Gbps; USB 2.0 transfer speed of up to 480 Mbps
* 80x80x15 mm blue LED silent fan for cool operation
* Includes easy stand foot, eSATA Cable, power adapter, eSATA PCI bracket and USB 2.0 cable
* Vista ready
* Thermaltake External Storage Enclosure products are warrantied for three (3) years for parts and labor.
From the review:
In our opinion Thermaltake Max 4 Active Cooling is one of the best HDD enclosures available in the market today. It provides both eSATA and USB 2.0 connections, allowing your hard drive to achieve the same performance as if it were installed inside the PC and at the same time having the flexibility of allowing you to connect it to a USB 2.0 port if the computer you are trying to connect it to (at a friends home, for example) doesnt have an eSATA port and you cant open it to install the SATA-to-eSATA bracket.
This enclosure was also fully compatible with the eSATA on-board connector provided by our ASUS P5K-E/WiFi-AP motherboard. Since some users are complaining about compatibility issues between eSATA enclosures and on-board eSATA ports, this is terrific news.
The material this enclosure uses is the best aluminum and it also has an 80-mm fan to cool down your hard drive.
Max 4 Active Cooling price is perfect for a product with this performance and features.
