Hey all just wanted to give a quick review of the Thermaltake Matrix VX. I did a new build and chose this case from newegg based on 2x 120mm fans and H/L of case.
Pros
- light weight
- 2x 120mm fans
- screwless
Cons
- Video card that need 2 slots, you will have to cut out part of the plastic retainer that holds in the PCI slots. Once cut, it fine ok and locked in.
- Power button - cheap! could be the one I got, not returning it now since build is done. However, when turning on or off it always sticks and have to play with it little to get it to pop out. When first built system and hit power button, it would begin to start up and then turn off. Took me little bit to figure out it was the power button and not something on the board.
out of 10 I would give it a 7. Its ok, but the power button really annoys me.
hope this helps anyone
Pros
- light weight
- 2x 120mm fans
- screwless
Cons
